arkyleo
Finally got tired of the left front wheel hop when braking --only between 30-45. I tried removing the rotor and sanding it on a mirror with various grits, but that didn't fix it, so I ordered new rotors and pads from LaMonster. The install looks pretty simple but I have not seen anyone mention lubing the pad pins. I have always done this (with the proper lube of course). My guess is that if the pins are clean and not corroded, it's probably not necessary. My BMW RT's needed the pins lubed or the first brake pull was a long one due to the pads not re-positioning correctly
