David Mitchell
I recently got my 2014 Can-Am Spyder RT back from the shop after a friend of mine ran into a curb and it had to be repaired. The majority of repair was on the right side. Basically, they replaced the struts, the tires, the fender, and other parts. When I got it back, the lights on the right side are not working, but the shop that fixed it said it's nothing they did. Nevertheless, I tried to figure it out myself and I'm stumped. Left lights low and high beams both work, but the right lights don't go on. The fender light also does not light up. I thought it was just a disconnected wire, but I did find a wire that I believe was cut. I don't know if that is the actual issue, but you can see it in the picture below. It's the green wire.. I also found a connector just hanging with nothing to connect to, but from what I can see, it wasn't supposed to connect, as you will see from the photos.
Any help would be greatly appreciate it. Thank you in advance
