Magic Man
Registered User
Although most of you have had no problem figuring out that the black plastic spacer that is on the right handle bar on the SM5 models because it has no front brake lever, is just to be slid off the old bar and slid in the new bar in the same location.
Still we have had some calls regarding this. :dontknow:
So, to help you with future installs...
The black plastic spacer that is just inside of the right side switch cointrols is to be slid off the old bar before you install the riser body and cut the bar. Then it is to be put back in the same location on the new upper bar stock once the riser is installed.
Although our SE5 has not gottren here yet.
The SE5 models have the same kind of spacer on the left side because of it's lack of clutch master cylinder on that side as well.
Again these spacers are to be removed before the riser body is slid on the bars and is to be transfered over onto the new upper bar stock on the riser kit.
I hope this helps helps any of you who may have questions on this. :thumbup:
MM
MM
