I have a 2009 RS SE5 with 26,400 miles. Occasionally the idle bounces around and the bike does not want to take off from stop, it stumbles and finally the rpms pick up and it runs smoothly. First time this happened, dealer replaced the plugs and new BRP wires. Lasted about 500 miles and started the same thing. Took it back to the dealer and they replaced the wires, under part warranty, and replaced the plugs. Ran great for about 500 miles. Bike went into storage for the winter and when I took it in for spring service they replaced the plugs and it ran fine, until today, when it started running rough at idle again. Is there anything else I should have them look at? They checked the vacuum lines during spring service and checked the codes. Would Baja Rons plug wires help solve this problem? Once rpms pick up it runs great, then idle drops several hundred rpm, and bike hesitates on throttle and then takes off after stumbling for a bit. Problem goes away for a while, then pops up again, several days later. When it is running smoothly at idle it comes on and accelerates smoothly.
I cruise it at 5000 to 6000 rpm and shift in that range also. In town I run first gear up to 35 mph.
Thanks for any suggestions.
