Symptoms and cause follow:
2013 RS w. 5300 miles, observed lack of resistance when depressing clutch lever. Hyd fluid was low, filled to full mark in reservoir. 6 weeks later, same situation happened again - had to push clutch lever all the way to the handlebar to make a hard shift. Brought to dealer.
Dealer's shop determined it is a failed clutch slave cylinder. The mechanic said the o-ring seals sometimes fail, easiest to replace cylinder unit (instead of o-ring). This is about an $80 part and 2-3 hours (fortunately warranty is still in effect on my machine).
Hope this helps if you have the same issue.
-Bodgerist
-Bodgerist
