RT 2020 vs 2024 - Is the ride different?
MRH
I was talking with another Spyder rider who strongly feels there was an upgrade to the feel of the ride between my 2020 and their 2024 (or perhaps it was a 2023). Both are RTs.
Wondering what others have experienced if you've actually spent time on the newer and older RTs since 2020 when the last major model change happened.
While my 2024 is my first Spyder I did not like the handling and before I had 1500 miles on it I went for new front shocks and the Ultimate sway bar. Now I like the way she handles
No question the anti-sway bar is game changer, and the shocks can also make a big difference for a lot of riders, but in this case I'm wondering about a stock apples-to-apples comparison between the years. I could easily see that just the sway bar difference could account for their experience if they didn't know it had been changed.
According to the parts manual, 2020 and 2024 Spyder RT's have the exact same part #'s for front/rear shocks-springs.
I believe the 2024 started using the new XPS tires, which would greatly change the ride.
On my 2020 RTL, the solid front sway bar end links made a night and day improvement.
Looking at the 2024 vs 2025 currently.
I had a 2020 RTL and traded in for a 2025 S2S. The stock ride is the same, but mine were/are heavily customized. First, do the sway bar upgrade. Then lose the crappy Kenda tires. Even the new tires are still very weak in the sidewall. As far as the operation, the 2025 (and 2024) controls are very different from earlier years. I personally like the new style but it takes a little getting used to. When the budget allows, go to better shocks. I have the Elka's. When you get the sway bar, good car tires, and better shocks, you'll think you are on rails. Oh, and then go for the Stage 2 ECU flash, when you really want to have fun!
The new XPS Roadster tires started on the 2025 model year. I have a 2024 S2S and it had the "old" Kenda tires. Changed them for the new XPS last month due to a tire bulge in one of them. They feel more comfortable a little bit but I also have the Baja Ron sway bar and shock adjuster on mine so can't say for sure.
The 'new' XPS Roadster tires aren't really all that new - they are still Kendas, and they still have exactly the same lightly constructed and poorly quality controlled carcass that Kendas have had all along! There might be a different tread pattern stamped into the outside, but on the inside, they're still the same old ****! 😖
