RT Airvents on 2016 model
eddieshep999
Seeing BRP has the vents designed for the heat recall on the 2013 model and several owners of other model years are also having them fitted. are they likely to be fitted to the 2016 RT model as standard and if so would they be coloured matched
Hey people, the reason for the need to Thank & Like before you can see any posts but your own is just that someone has set their advanced posting defaults (could be system wide for all I know?!) to demand those when they post, & if you reply to one of those posts, unless you've changed the defaults back to NOT needing them, your posts demand the same!!
Simple solution if you see a heap of Thanks & Likes under the post above yours, then before you post your reply, just click on the appropriate check boxes in the Additional Options field below the text box - not hard to do, and it means that you aren't perpetuating the difficulties for all the readers after you!! :opps:
:thumbup:
No, the 2014 and 2015 models have no need for them, so there is no reason to think that a 2016 will. The heat issues were solved in far better ways from 2014 forward.
