RT Fuses?
You should be able to buy most of them at the auto parts store. The 25 amp fuse is only available from your dealer.
Where can we buy the main fuses used on the RT? The ones under the seat. Is there a tool to remove them? Bob :dontknow:
I know the GS/RS uses a standard length j-case fuse. I ordered my spares from here, including the 25 amp:
http://www.mouser.com/Search/Refine.aspx?Keyword=jcase+fuse
Of course I don't know if the RT's use the same style. And, unless you order a few, the shipping may make them more expensive than buying at the dealer. I don't know of any puller for these type fuses.
got my fuses at Autozone. had to order the 25 amp fuse from dealer. not expensive but they had a @#$#@$ of time getting the correct part number to order it. kept getting the mini flat fuse.
these are the LONGER mini fuses when you goto Autozone to get them.
