RT trailer hitch ???
If it's a BRP hitch for an RT that you want to fit on another RT, then it should fit regardless of what year the RT is! :thumbup:
If it's a BRP RT hitch then as Peter stated it will fit all year RT's as well as the F3t and F3l (wiring harness will be different between the F3 and RT's).
The swingarm is fractionally bigger on a 2014 then on a 2012. BRP has a different part number for different model year ranges for that reason. But the reality is that the difference is so small that it will likely fit. Most do. If it does not a little bit of sanding on the hitch will get it to fit.
hitch
Thanks all. Yes it is a BRP hitch so i will go with it.
