Sarge707
After trying to fish wires through the body of the front turn signal I came up with a easier way!
1- Take off bottom/Rear banjo fitting . (2 Screws)
2- Route your wire through the hole- For me it was from the bottom of turn signal -others might be inside near mirror!
3- Drill small hole in banjo fitting wall toward the center hole with OEM wire.
4- Drill small hole in center hole wall facing Banjo fitting.
5- Thread your wire through and replace Banjo fitting cover.
6- I Tapped in (After Stripping off cover) Just behind where the little info tag was.
7- BE SURE to leave about 2-3 inches slack in your Tap In wire because you will stuff the Posi-Taps back into the hole.
The finished Product has the 12" Amber strip on the outside and is Very visable from behind and off to the side at a 90 Degree angle Like if your approaching a side street. The bottom lights are visable to the driver BUT since my 2012 lights cancel Really well I was more concerned about others seeing them Sooo I put them around the perimeter!!
Cost me $20 (Autozone) and 4 Posi-Taps. I Might purchase 16" Amber lights in the future so they would extend All the way on the Top and be visable from the Direct front as you don,t see these Head On!!
