mikecronis
Still haven't bought yet until the crypto-winter is over (for those who know, as it follows the failing Nasdaq.. politics aside).. so I do NOT own any Spyder at this time.
I am familiar with the Spyder line, however, as I've owned a 2013 RS-S and RT-L with the older Rotax 998..
I believe the RT-Limited has the Lin-Q setup already installed (please correct me otherwise) which means you can remove the rear-seat/speaker setup fairly easily (so I hear). If anyone has a few pictures of that, I'd be appreciative.
If it does not then I'd have to add Lin-Q I suppose..
So... question is:
If the rear panel - https://can-am-shop.brp.com/on-road/us/en/219401076-rt-rear-panel.html is replaced with the rear seat setup (using LinQ) is it easy to interchange and how is the wind-change for the rider?
I remember the 2013 RS-S with the added saddlebags by GIVI - https://wrapmyspyder.com/shop/fullbody/rs-st-saddlebag-insert-kit/ definitely changed the wind wrap-around affect significantly. I also suspect any modification to rear compartments will affect wind to the rider as well. Has anyone noticed or done this?
So... question is:
