Ryker front radiator plastic tip - replace the Torx screws with hex head before they get scraped! :)
Kickstart
Howdy Ryker pilots! :)
The 2 screws (underneath the grill cowling) take a #30 torx bit to remove. Cool. But today I had to remove them and had a problem. It seems a speed bump scraped/disfigured the screws so that the #30 bit would not go in. Luckily a #25 did kind of fit and worked!
My tip is, replace those torx screws with hex head metric screws. Same length, etc. If they get scraped you will have more options for removal. :) Pack a proper wrench to your tool kit.
Cheers and see you on the road. :)
