noboot
I tried positioning the arm at the bottom and going up a click each time and trying to press the DOWN button but nothing happened. When I press the UP button at each position, the arm moved UP? Really weird? Someone mentioned:
it has to do with the magnet position on the left end. I left the top clamps off and kept repositioning the coller. That did not cure it. I finally had to pop the magnet out and shaved the plastic a little and glued the magnet in once it worked properly
I may try this tomorrow
Try rotating the arm 180' (in other words turn it upside down to the way it's sitting on the shaft now) Also make sure it's positioned half way up and not right at the top or right at the bottom. We have had this same problem a number of time and when people rotate the arm it has worked.
