here's my 2 cents on the tires. First, BRP claims 40% better wear than the Spyders. I am guessing that is due to the lightness of the Ryker. Second, I would be very, very concerned about putting car tires on a Ryker. Car tires are expected to bear approx 1,000 lbs of downforce per tire. The compound and stiffness are designed for it. On a Spyder RT, weighing 1200 lbs wet, with 400 lbs of rider/passenger and gear, you have 1600 lbs divided by 3 wheels = 534 lbs of force. That is why car tires last a long time on an rt, but also why they will never stop as quickly with car tires on it. Now look at a Ryker. At 630 lbs wet, add a single 250lb rider, and you have 880 lbs divided by 3 = 293 lbs of horizontal downforce on the tire. So you have a tire designed and rated for 1,000 lbs of down force getting only 1/3rd. It likely won't stop, and it might not turn. Bad idea, when you are saving $40 but you end up in the other lane or underneath the car stopped in front of you. What did you save?
One other comment. The lateral force on a tire is directly related to the tires durometer measured compound, contact patch area, and horizontal down force. All I see from a wider, harder compound front tire is increased steering effort from a larger frictional contact patch (rotational lateral force) but even less horizontal force as the tires weight will be further diluted by the larger contact patch. It is a lose - lose deal. The bike will be harder to steer, and it will slide quicker! The car tire idea is a terrible idea for a Ryker in my opinion.
@Triumphcycleman,
With all due respect, I understand your point of view. This is not about saving money, in fact quality auto tires cost more than Kenda tires. Many Spyder riders, including myself replaced our Kendas when they worn out with auto tires for several reasons. Kenda tires are very sensitive to front end alignment. Kenda tires wear very poorly if the alignments is not perfect, so BRP's claim for such long service from Kenda tires will only be true if the alignment is perfect. Kenda tire are not great on wet roads. Kenda tires wear out down the center of the tire tread on the rear tire regardless of the operating tire pressure. Kenda tires do not in general handle well. Do a search for "Tires" on this Spyder forum and look at the hundreds of threads, you will not find many Spyder owners bragging about how great Kenda tires handle, some Spyder owner have fair luck with long tire tread life, but that is the minority of the respondents.
In general Kenda tire are not built to high standards. They represent a good revenue flow for BRP. It appear BRP has every intention of retaining Ryker owner tire purchases with BRP. If you choose to use Kenda tires that is wonderful and I'm sure you will have many followers, but for myself and many other Spyder owners that have a working background with Kenda tires it is very frustrating to learn the "No option other than Kendas." We have experience what quality tires can do for the Spyder.
Tire selection for the Ryker is an unknown, especially since the Ryder does not have power-steering. The power-steering is poorly understood by most BRP riders. It's main function is to isolate feedback into the riders arms. The "power" level of assist is regulated by the CPU that is watching the rate gyros, wheel speed sensors, and input torque on the steering handlebars. The power-steering varies it control of feedback to the rider arms based upon the PID, (proportion, integral, derivative) computations. If a Spyder is not in alignment and the tires are of poor quality (Kenda) then the handling is terrible! If new tires are installed but the alignment is still out the Spyder will feel much better, but not right until it is correctly aligned. I proved this to myself on my F3T. Tires make a huge difference on safety and handling for the Spyder. I suspect it would be more, if not the same for a Ryder since it does not have the power-steering to dampen the road feedback into the riders arms.
I'm sure you'll have a fine time with your new Ryker using Kendas, you have no other choice at this time.
Have fun with your new toy.
EDIT; @Triumphcycleman. On your first post to Spyder Riders you introduced yourself and said that you are now a "BRP Spyder dealer". I guess you will profit from the exclusivity of "Kenda's tires only on the Ryker". Does this explain your comment? I quote you here: "The car tire idea is a terrible idea for a Ryker in my opinion"
