Screeching sound from right side engine bay of 2013 RT - any thoughts on cause, fix?
davos
Hi, I've got a horrible screeching noise coming from the right side engine bay on my 2013 RT LTD when the throttle is off, any thoughts, David
Thoughts? Yes, and they're all expensive. But first, when you say “when the throttle is off”, you mean with the engine running at idle? When you raise RPM just a bit, are you saying that the noise immediately disappears? Just asking if that’s what you meant and if that is significant. Plus, do you have any warning lights lit on the display with the engine running?
Hi Doug, the noise disappears when you open the throttle and there aren't any warning lights
Well, David. I suppose that the good news is that you don't have a Low Oil Pressure Warning Light on. But, that only deepens the mystery. Especially because it is so RPM sensitive - that's a bit weird. Would it be a metal-on-metal noise, or maybe some weird acoustic noise in your intake - especially if the air filter is one from 2013, or some foreign material in there. Is it something that just happened suddenly, or can you link it to some mod or maintenance activity that happened recently?
If it was mine, I would pull every panel off of BOTH sides - you know how noise can travel - and investigate. You're just going to have to get your head deep in there and try to narrow it down to a specific location on the engine. The bottom end of the right side of the engine is where all of the power train gears, chains and bearings are. Hope it's not that. Might be something as rare as this, just at a different RPM than the example listed. Good Luck.
https://static.nhtsa.gov/odi/tsbs/2013/MC-10129604-9999.pdf
