No, it doesn't move around and I think I've found it! Heeding the advice of many on this forum about shifting at higher rpms, I've been experimenting with 4k, 5k, and 6k...even running sometimes into the 7's on my RT-S and believe I've hit the spot that makes the Redman sing, hum and ooohh and ahhhhh and sip gas more prudently.
Yep, I get the best feel, the smoothest shifts and the most satisfying sounds from that 998 CC beast at 5,000 ripums. Put yourself at a traffic light; it goes green and you go zoom, 5k rpms, 25 mph, first gear..shift! Ah, so smooth and satisfying. Up to 5k and 35 mph, second gear; 5k, third gear, 45 mph. Now, fourth gear and 5k rpms, 55 mph and smoothly into fifth gear at 5k rpms and 65 mph approaching 70...humming merrily along while all those cages and rumbling two wheelers back at the light are barely out of the chocks. Your Spyder loves it and you?....you've found its sweet spot! Works for me!
With that in mind wonder if BRP will consider on new models marking the rpm guage at the 4,500 to 5,500 mark with subtle "shift" marker. Save them a lot of warranty work on clutches and you and I lots of down time and other general bitchiness. They could simply put an insert in each new owner's manual talking about proper shifting. Let's see if it happens....:bowdown:smoky
