Should I be checking pressure in the Rear Suspension Air-bag? '19 F3 Ltd
sparky1947
My short list of personal friends keep telling me to make sure that I check/keep after the PSI in my rear suspension bladder. My confusion is this: In the Can-Am 2019 Spyder F3 manual/operator's guide on page 56 under Adjusting Suspension > "Rear Suspension (F3 Limited Models) it says this: The rear suspension level automatically adjusts by deflating or inflating the air spring. Am I to assume that that means that there is no keeping after/checking that I have to do to maintain the rear suspension?? As in self adjusting air springs. I am retired from truck driving where most rigs employ the use of self adjusting air bags on the tractor and most trailers, i.e. no driver/operator maintenance needed. Is that the same case in the case of these rear suspensions on the F3 Limited? Thank you. See attachment.
Spyder F3 Limited
Oxford Blue
If you have the limited model you are very right!! If you don't have the limited then you would have to keep a eye on it. I changed mine over to the manual fill after the compressor decided to crap the bed on me, I find that I check it every spring when I service it, and yes in most cases it needs a little air! If my ride seems a little spongey throughout the season I will check it again, but it will stay good for the most part! My happy number for my wife and I is 60-75 PSI.
I have an F3 LTD. While it has that seat button under the pillion seat I have not yet located a valve to confirm the pressure.
rear suspension F3-L
unless the limited is different from the F3-T you will find the Schrader valve behind the drivers seat on the left after you remove the passenger seat.
Al in Kazoo
Ah OK. I will pop out later on and have yet another look. What pressure for a Munchkin of 100kg / 220 lb ya recommend?
Iso, sorry, I can’t remember…….does your 17F3-L have the auto adjust bag? (My ‘16 F3-L didn’t have it, but my poor memory believes they introduced it in ‘17 for the F3-L). If it does, and if you do find the valve, I would strongly suggest putting some kind of tpms monitor on it. I have one on my ‘21 RT, and it makes it so easy to monitor psi at rest, under load, and when underway. That TPMS on the bag’s shraeder was what clued me up to the fact that my ‘21RT had left the dealer without the little sensor arm being connected.:thumbup:
Pete
Earlier models have to adjust air pressure manually. Later ones are automatic. Mine is a 2016 F3L and has to be adjusted by hand.
I believe there is an accessory kit to make it automatic but knowing CanAm and their pricing, I think I'll keep it as it is...
That bit is probably a good idea, and not just cos you'll be saving yourself many wasted $$! :thumbup:
Many Spyder Owners who paid extra for Spyder models with the Automatically Controlled Suspension systems have removed/disabled the 'automatic' bits, simply cos the ACS as delivered is often such a pain to keep working properly. :banghead: The automatic suspension concept is a great idea, it's just been very poorly executed right from its initial implementation, and despite all the difficulties and issues reported with it since 2010, to date it remains a frequently problematic system that BRP seem to be ignoring, much to the cost & regret of those Owners suffering from it's failure! :gaah:
At its most basic, it's frequently not even connected properly by the dealer/techs doing the bike's initial assembly; and even once that is eventually connected up correctly, for many, the 'automatics' of the ACS remain extremely unreliable despite frequent attempts by dealers &/or owners to resolve the issues; so much so that for many owners their preferred way ahead is to disconnect the 'automatics' & revert to inflating the air bag manually via the schraeder valve once or twice a season instead - something that seems to work well for most! :thumbup:
Just Sayin' :rolleyes:
Pete
Trust me when I say you will know when your bags is getting low on air, well without a TPMS, and the cost of it. The less than adequate shock will let you know, that thing is just a pogo stick under there! And you will be banging on your frame at every bump in the road.
Yes, I agree, that is the case with the OEM shock, Mikey, but that wasn’t the case for me. I had an OEM shock manufacture issue from day 1 and immediately swapped my shock out for an Ikon, so I had great suspension that wasn’t bottoming. The disconnected air bag was a separate issue that FOBO highlighted :thumbup:
Pete
Mikey, do you have any pics or suggestions on how to install the manual fill? I need to do something as my rear suspension is dead.
Chicago I can work you through this. I just had to do it on mine. My airbag needed replaced totally. It had a bunch of holes. First strip the entire left and right side panels off. I made it simple for myself. If the bag is bad remove the shock and exhaust. If the bag is good then you are looking for the line that comes out of the top of the airbag. It should be the 1/4 line coming very close the rear shock and into a white plastic manifold. Once that line is located coming from the airbag, take a knife or scraper and pry the connector end towards the line as you push the line in. The hose will slide out of the connector. That connector should located in the front left of that manifold. Next look for the shreader valve. Trace the 1/4 hose to the same manifold. Should be in the rear left. Pry that connector off. Now that you have both hoses free, go get a good 1/4 hose coupler (brass) and join the 2 together. (Truck DOT diesel places will have them) You are finished. Air from shraeder goes directly to bag. To leave air out simply push the center of shraeder. Hope that makes sense. Look for the white square block with all the hoses coming in on the right side just under seat. Thats your manifold. Stick your hand between the shock and frame and look at bag. At the top behind the U bracket is the elbow with hose coming out. Mine was zip tied just in front of shock to not get caught. Thats the airbag hose. And trace the shraeder down. Connect the 2 and done!
Spyder F3 Limited
Oxford Blue
sparky1947,
I have a 2023 F3 LTD Special Series and it has the Rear shock w/self leveling air preload adjustment ( Travel 132 mm( 15.2 in).https://can-am.brp.com/on-road/us/e...yder-f3.html#spyder-f3-limited-special-series
Last week I packed for a trip, to Lake George, New York ( Spyder Quest) I used the back passenger seat as a place to carry some luggage, I did not have to adjust the rear shock for the added weight on the rear shock. The rear shock adjusted automatically. The bike handled well.
Deanna
