Bought a pair of Cree high output LED strips, rated for 565lumens and 6.5 watts per foot. https://gorecon.com/product/12-flex...h-power-flexible-light-strips-cree-led-white/  Unfortunately the math doesn't work out, because they also spec that they draw 285ma which works out to 4 watts.  I measured it at 205.5ma @ 12.45v which works out to 2.55w.  So the actual wattage consumed is less than half of what they spec, makes you wonder if the other specs are also fudged.
My son built himself an integrating sphere so if I get curious enough I'll pass it to him and have him give me an official measurement of lumens. Regardless they're pretty bright.
Untitled by Uncle Grr!, on Flickr
And stickied it on where the signature light goes.
Then I drilled a hole, tessa taped the wires and ran them into the bike. I crimped on a connector to the customer accessory wire
And tessa taped it to match factory. Then I soldered in a 5a fuse to the mating connector (I was out of fuse holders for that size) and connected it to the light wires.
Then I taped everything up, ran the wires and added some zip ties as needed to clean it up.
And the first test showed three dead chips. Sometimes they'd work, sometimes they'd flicker, sometimes they were off. I pulled that one off, contacted the seller, and installed the other one.
And here's what it looks like with the replacement
Untitled by Uncle Grr!, on FlickrAnd stickied it on where the signature light goes.
Untitled by Uncle Grr!, on FlickrThen I drilled a hole, tessa taped the wires and ran them into the bike. I crimped on a connector to the customer accessory wire
Untitled by Uncle Grr!, on FlickrAnd tessa taped it to match factory. Then I soldered in a 5a fuse to the mating connector (I was out of fuse holders for that size) and connected it to the light wires.
Untitled by Uncle Grr!, on FlickrThen I taped everything up, ran the wires and added some zip ties as needed to clean it up.
Untitled by Uncle Grr!, on FlickrAnd the first test showed three dead chips. Sometimes they'd work, sometimes they'd flicker, sometimes they were off. I pulled that one off, contacted the seller, and installed the other one.
Untitled by Uncle Grr!, on FlickrAnd here's what it looks like with the replacement
