silver handlebar peice
brutus450
anyone know how hard it is or what you have to do take off the silver piece between the handlebars? want to take it off for painting
It unbolts from the bottom with 4 machine screws. I've done it once (but didn't take photos as I was following BRP's instructional sheet for the riser) to put the BRP 1" riser on and would strongly dislike to try to re-install without the riser as the room to re-install the screws is very, very tight.
If no answer by tomorrow, I'll scan the instruction sheet and post.
Wayne
I believe there are 6 bolts. Four across the top are 10mm and the two on the bottom are 8mm. :dontknow: Don't know why they did that, but it liked to have drove me crazy.:gaah: Very little finger room.
Don't forget the rag to stuff in the hole around the steering shaft. If you drop one of these screws into the bowels of the machine, you may not ever see it again.
1/4" drive slim profile socket from Sears will make this easier, but still no picnic. 1" riser does provide more working room, but everything is done mostly by feel. Big hands, big problem.
