SM10 Won't Pair
muleman1
Got an Sm10 and a pair of SMH10's this week...but can't get the Sm10 to pair with the first headset. Any ideas from the brain trust out there?:sour:
Just got my Sena's yesterday. Went through the pairing process for the pair A & B. Everything worked per lights, sounds, and beeps--but I did not try them out yet. For pairing a third unit, directions say then to go through the same process with A & C. The directions leave a little bit to be desired, and I have not installed them in the helmets yet. I am replacing Cardo 2's.
If you paired the headset with your phone first it might have taken the A2DP protocol and that is what the SM10 uses. I would remove all pairing as per the manual, pair the 2 headsets and then pair the sm10.
I agree. I actually got them on the phone, very helpful. They walked me right through it. No problems since.
how did you pair with the SM-10? I paired my SMH10's together, then used the phone pairing button to pair with the sm 10 on each headset. Works like a champ!
