let us know what it was!:dontknow:I have it in the shop now getting checked out. Have a great team that works on my RT. Hope its something simple!
Hello all;
I have a 2011 RT-S SM5. It has been great for the past two years, now that I have 15,500 miles the clutch has started to slip. I was on I-95 doing about 60 MPH. Is this about the time the clutch startes to go?
Thanks and be safe out there.
Chief
I am no expert but was told the SM5 has a wet clutch. Check you oil level maybe?
Bob
thought i had a little slippage a month ago and found out it was due to dirty hydrolic clutch fluid. normally i guess that is supposed to be checked every four to five thousand miles. mine had 12.000 miles on it and it had never been changed. once changed and bled, no issue. good luck!!
The 1st thing I would ask is what oil are you using? And have you put any additives into the oil? That is very low mileage to have your clutch slipping. I'm pretty hard on my clutch and it's fine at 35k+
If you are not using a JASO MA2 rated oil I would definitely change it regardless of which Spyder model you're riding.
If you do not know what your JASO rating is it is a very good idea to find out. Once the clutch starts to slip you are looking at a pretty good repair bill in short order.
You know the old adage, an ounce of prevention....
How do you know that your clutch is slipping? What are the symptoms?
You give it gas and the engine revs but you don't go anywhere or if you do it is slow acceleration.
Bob
Ron, originally BRP stated you absolutely had to use their Synthetic oil in the Spyder or you might have catistrophic failure or some such non-sense,,so now BRP ( without any major changes to compensate ) says their BLENDED oil is fine ? ? ?........Do you know of ANY blended oil that meets JASO MA2 specs and I believe in AMSOIL .......Mike
I'd be surprised if the blended oil met JASO MA2 standards. If they are labeled at all, it would likely only be JASO MA. I know of no MA2's except full synthetics, but there might be some. I don't think the BRP oil is JASO labeled at all...and they do not specify a JASO rated oil, unless they recently changed.I would assume that the Blended oil BRP sells meets JASO MA2 standards. But from what I've heard it doesn't list specs on the container so who knows. But if it did not I think we would see a lot more slippage so I would not be concerned about clutch slippage using any of the BRP recommended oils.
But if someone topped off with the wrong oil or changed to a wrong oil, that can spin your clutch in a hurry.
The Spyder seems to be more susceptible to clutch slippage than most motorcycles. It may be that the spring pressure is a bit low to keep clutch lever pressure low (at least in the Manual). But for whatever reason, you need to stay away from low rated or no rated wet clutch specs.
One more thing that people don't always realize is that there is a range within both the MA1 and the MA2 ratings. Your oil could be near the bottom of the MA2 rating and be just a bit better than another oil at the top of the MA1 rating.
Amsoil isn't the only true synthetic out there but their MC oil is near the top of the MA2 rating which is a very good thing for our Spyders.
It is true that if you catch it soon enough and do a complete oil/filter change to a good JASO MA2 rated oil, you can usually save your clutch and live happily ever after. It's certainly worth a try before buying a new clutch.
