Is there a special rpm that one should shift in order to get a smooth shift without the hesitation that sometimes happens ?
On mine, with the engine fairly cold, I have smooth shifts at 5,000 rpm; when it warms up a little less than 5,000 rpm seems to work for me.
Glynnk
The thing to remember when shifting is that you have to be at high enough rpm in the new gear, that the transmission won't want to shift back down. The Spyder drops about 1,000 rpm per gear in the upper gears, so shifting at 3,000-3,500 rpm would drop it to around 2,000-2,500 rpm...at which point it would want to automatically downshift again. This is what causes the hesitation sometimes. The poor thing is just confused! A little more rpm is not a bad thing, and will usually not hurt your gas mileage, since if you are too low on the power curve, you would tend to open the throttle further to compensate, using more fuel rather than less.Interesting info on this blog. My transition from my Harley to RT
SE-5 answered here. I have been shifting around 3000 rpm and sometimes get a hesitation / hiccup when it shifts. So taking all this in as stated I'll make adjustments and use higher rpms. Certainly a continued learning process on these magnificient machines.
There are some very good reasons to use higher rpm. First of all, at too low an rpm, the Spyder will refuse to shift at all, because it would drop low enough in the higher gear to just immediately shift back. Second, under high load conditions, it is very possible to lug the engine, straining the bearings and causing possible detonation. There is a reason they raise the shift point in trailer mode. There is a big difference in the range of the power band on the Spyder engine, with a redline of 9,000-10,000 rpm and an auto engine with a redline of 5,000-6,000 rpm. Shifting the Toyota at three grand is doing it at around 50% of the rpm range, while three grand on the Spyder is only 30%. That is certainly not where the engine is happiest. JMHOI just came back from riding tonight and found that I prefer to shift around 3000 rpms with the throttle released each time. I find this to be smooth with almost no hesitation of hiccups. It is exactly the same in my 02 MR2 Spyder convertible. (5 speed ). Just let go of the gas, push in the clutch and shift. This is how I shift in my car. Shouldn't it be the same ? Do we need to use higher rpms for any special reason ? I do make the shift at just over 3,000rpms on the Spyder.
Motogordo:yes:
