Solutions for handlebar vibrations?
Just Doo Me
What have most people found to work best to reduce the vibrations through the bars? Grip puppies,weighted bar ends etc. I have replaced the stock grip with a gel grip.I run my frt.tire pressure at 20 psi rear at 28 also shocks are 1 notch from firmest.I could back these down but would then lose the handling in the twistes:dontknow:.Recommendations?
Heavy Throttlemeister, Bar Snake & grip puppies work well.
You don't need the heavy throttlemeister...the normal size works just fine...IMHO, it fits the contour of the bike a little better too...
Either will work, plus you get the added benefit of a mechanical throttle lock so that you can rest your right hand on longer rides!
Get two birdies with one stone!
Highly recommended!
Go old school and toss a roll of nickles in them. :D Actually you'll probably get the best results from the bar snake. Of course if you want to lessen the vibration and get a more comfortable ride at the same time go for the NMN risers. :2thumbs:
DooMe:
Get the SS bar weights from CANAM, and pump up the tires to the proper pressure. I did.
Ride Safe
2faston3
Highly recommended!
i disagree...i think the heavy being longer makes it ezier to operate for me...and the more weight the less the vibration
Must of been bigger bars or smaller nickles because I just tried a nickle, penny and dime on a cutoff bar I had and none of them will go in the bar. :dontknow:
Now I have heard of using lead shot and BB's.
picture.php
Thought about that after I'd made that post. I was thinking about when I had my Harley's.
I knew about the spyder and harley bars, but not that most asian bikes used the 7/8". Makes sense that you used the 7/8" bars to check now.
