Spyder Just Died
vampyregirl
As I pulled up into my driveway, thank God!!! I'm thinking it needs an oil change, as one hasn't been done in a couple of years. No funny noises, no grinding, etc. Poor thing just shut off while in 2nd gear. I still have electrical, but it won't start again. Mind you, this was after a 3 mile ride from mom's house to mine. Had to sit for about 3 mins while a train went by on the ride home--and I put it in neutral while waiting. The only "idiot" light that comes on is the oil light when I try to start it (after you hit the button before you try to start it). This is why I'm thinking oil.
I must admit, it's been a couple of years since an oil change. I just haven't been able to ride much at all. Maybe put 400 miles on it between last year and this year -- if that.
Any opinions??? Or suggestions??? I'd like to try and do an oil change myself before I have it towed to the shop, unless you folks can give me a reason not to. I don't mind taking it apart, since I've done a bit of that before.
Anything you guys can give me would be appreciated!!!!
Interesting
What happens when you hit the starter button? Very odd that it just stalled and won't re-start.
SE or SM? Doubt that oil level or condition cause that. Original battery? Do you keep it on a tender? Check for loose or corroded battery cables to start with. How old is the fuel?
sounds like an electrical issue or weak battery.
It's a 2011 RS SE5. Absolutely nothing happens when I hit the starter button. No noise, not even a click!! I just put in a new battery last summer, and it gets put on a battery tender for the winter. Started right up when I went to ride it the first time!! I've been out riding a few times this season, and no issues. I still have lights and such.... And I just gassed up a few weeks ago--like I said, haven't been able to ride. I live in Ohio where so far we really haven't had summer yet. We've been having monsoon season here!!!
I REALLY don't need a repair bill right now!! Still dealing with flooding issues from 2 weeks ago. I didn't get much water (it seeped in through the walls), but there was some I didn't know about. It caused some lovely mold in the basement!!! Just finishing up getting that squared away. Sigh....
I know I will HAVE to do an oil change either way. I won't be able to check the battery connections until Sunday. I have to put another coat of waterproofing paint on the basement walls before we get more rain on Sunday!!! UGH!!!
Thanks for the suggestion!!! I thought about it being the battery, but I kind of dismissed it because it's a newer battery in there. I'm not discounting anything at this point!! And I do believe I have a battery charger in the garage (as every chick should ;))!!
Wasn't the kill switch. I rarely use it... I thought I maybe went up the driveway too fast at first... :opps: Come to think of it, this may have happened when I had to replace the original battery. At least it waits until I get home to pull this crap!!!! :bowdown:
It's in 2nd gear so starter won't work unless your foot in on the brake. So is your foot on the brake?
Normal for the oil pressure light to be on when the engine is not running. The engine runs the oil pump. Likely the same as your car.
Bad fuel? fuel level. Also put battery on regular charger prefer 5 stage one or take to batteries plus to charge/ check.
Hmmmmm
Check battery charge, and connections. Tight and clean is good. Should be 14vdc. If not, charge on a regular charger, not a trickle charger. Check oil level, add if you need to. Should fire up. Good luck! Joe
Interesting..!!
:agree: with all the above. The oil needs changing no doubt but not the cause of it stopping. By all means check it and or change it when you get the chance. Double check your kill switch, many inadvertantly bump it even while ryding. Try the starting proceedure with jumpers connected. If it starts you need to charge the battery and or check all your connections. Let us know what you find...:thumbup:
Foot was on the brake!! I'm a thinkin' battery the more I see you guys' suggestions!! I'm too tired to pull the battery this evening, so it will have to wait until tomorrow. Been burning the candle at both ends with work and coming home to take care of the leaky basement for the last 2 weeks!!
Thank you all for your input!!!
It's the 2 year old battery!!! Pulled it, put it on the charger to see if it had a charge left... 1.3 amps. New battery tomorrow. And then I can sit on it in the garage since it will be raining...again. Soooo sick of the rain.
If you are not riding it much, be sure to get a battery tender for it and hook it up when it is parked at home. You can get a good one for around twenty-dollars or so. It will help your new battery remain a good one for a lot longer.
I do have a battery tender. And a new battery now as well!! :D The guy at Battery Wholesale tells me it may be my charging system since these batteries should last 5 - 6 years. Uh-huh. The bike has sat for 3 weeks before without being used and without being on the tender. Never had and issue with this battery until now. I didn't trust the old one any more and bought new. Problem solved!!
I just love it when folks try to solve your problems, but don't even ask what type of bike or anything. And dude was definitely NOT a motorcycle rider. I told the guy that rang it up what kind of bike I had and he said yeah, I wouldn't trust the battery with that bike either. Uh-huh. This is one of those times where I really don't like being a woman because we get treated like crap in most situations involving mechanical stuff!!!
And, for the record, I checked the connections before I pulled the battery. Everything was tight. I'm thinking one of the cells went bad right at that moment that it shut down on me. Before that, there was no hesitation in starting up or any other hiccups.....
Glad you got it worked out
Well I'm glad you got it worked out and back up and running.
What kind of battery failed and what did you get? I Got a YUSHA from Honda East on Saturday. My original battery did not fail, but... it was sluggish starting, :shocked: so I replaced it. I tend to opt for the safe side of the street. :ohyea:
Frank
Not sure but I would also check you alternator output and make sure it is working optimal..:thumbup: This would also cause a battery to not work properly or kill it sooner than expected.
