It should, might have a clearance problem on the side. I have a HF lift (yellow one) that works great to pick it up, but when I let it down, it drops like a rock.nojoke The release valve seems to have 2 positions -open and closed. You might check the release on this one.
john
I am considering a lift. I looked up the specs on the the red and black Craftsman. It says minimum height is over 5 inches. Is anyone using this particular model?
http://www.sears.com/shc/s/p_10153_12605_00950190000P?keyword=Motorcycle#reviewsWrap
Thanks groundeffect, i was wondering what that model was.
Mark the Craftsmen works well both models they sell work HDX has the red one :ani29: I have the yellow :doorag:I am considering a lift. I looked up the specs on the the red and black Craftsman. It says minimum height is over 5 inches. Is anyone using this particular model?
