BryanSD
I'm having a "new to me" problem with my 2017 Spyder RTL that I'm hoping others can point to me toward the cause of the problem. I'm the original owner. Over the summer, I've started to feel every bump in the road and occasionally shaking at a level I have never experienced before. I originally thought it could be a balancing issue, as this summer I also had the dealer replace my rear tire (same as previous tire, the Kenda KR20 Kanine). However, when I'm on freshly paved asphalt roads the Spyder runs smoothly and it's only the more worn out roads where I'm starting to believe it's a suspension issue. Is it possible it's the front shocks going bad and if so, how do I confirm it? I'm pretty sure the rear air suspension is working fine but is there a way to confirm that is working as expected?
Sorry for getting so basic here, but with no error codes and only seeing the Spyder's VSS kick in once or twice. I'm just needing an idea where I need to throw my money or time for a smoother or safer ride. The last thing I want to do is have the dealer waste my money on labor costs and solutions that might or might not fix my issue. It probably doesn't help that this problem isn't sudden as much as just snuck up on me over time to drive me a little crazy.
