Squeaky brakes
delkhouri
I rode down a dusty/gravel road the other day and now my brakes squeek. I have not done anything yet to fix it. What should i try first?
Hose everything off good with some mild soap. Dust will cause brake squeal, regardless of the source.
I gave the ryker a good wash spraying the wheels and brake area.. then went for a 15 minute ride and heard to squeaky brakes. Thanks for the tips. Thats what i thought i should do but just thought I should ask first.
I also have the squeaky brakes. washing and hard braking will sometimes help but they always come back. idk what would fix it other than changing pads.
Your issue is typical. You can change pads but will probably end up in the same place. There are a number of things you can do. Applying CRC Brake Quiet (or similar) to the back side of the pads, sanding the rotors with some Emory paper, spraying the rotors with CRC Brakleen. Be sure your pad to caliper friction surfaces are clean, smooth, and have a good (thin) film of Anti-Seize applied to them.
I figured. thats typically what i do with the brakes on all my cars. now I'll have to get the socket to remove the wheels first. not too worried about it until its time to change pads tho.
