As someone who has had a little experience with bad gas & the damage it can cause/how much it can cost to fix AND the extent that Servo owners & even oil companies can sometimes go to in order to avoid paying for the damage they've caused to your vehicle, I can see that there's lotsa good advice here already, but some, maybe not quite such a great idea!! :sour: If you are really lucky, the 'bad gas' won't have actually made it past the fuel filter; just got that far, clogged it, and stopped the engine due to fuel starvation more than anything else!! When the engines shut down it should've been a fairly quiet thing, basically just a loss of power & revs then a glide to a stop if the filters did their job properly! And if that's the case, it really should be not much more than a 'drain & refill with good fuel' job; change the filter; then pop the plugs &/or injector lines & crank til all the lines are clear & clean fuel comes out; then reconnect everything; restart & Bob's your Dad's brother! :2thumbs:
Buuut, if the engines started banging & popping & maybe the engine temps soared as things started running rough & making odd noises before they lurched & banged to a stop, then you might need a fair bit more work on the injector system as well as doing the 'drain & replace'; maybe even some remove & replacement work on things like the fuel pump (in the tank & a right pain to get at!) &/or the injector nozzles or complete injectors and maybe even valves or worse!! :shocked:
I really hope that it's not gonna be anywhere near that bad, but you should speak to your insurance company and more importantly the oil company & outlet immediately, preferably before you go doing anything like adding anything to your tank!! :yikes:
At the very least, siphon a sample of gas from each tank out into a clean glass container that you can seal & label clearly with which Spyder each sample came out of, adding the date, time, & the location you removed it, & why you took the sample! The 'unchanged/unmodified' make up of the gas in your tanks & the analysis of same may be extremely important in deciding exactly WHO pays to remedy the mess & any resulting damage! And since in the worst case scenario, the necessary fix could involve a new engine, you really don't want to inadertently risk bringing that cost upon yourself by adding any fuel treatment that could dilute or react with whatever the contaminants are in any way, potentially destroying any real evidence there may be & any case you may have ever had that it all stemmed back to the dodgy gas you purchased! :yikes:
I really do hope you get it sorted quickly & easily, but it's always best to take precautions in case that doesn't happen! Good Luck! :thumbup:
