On my 2012 RT, I installed a sway bar, didn't really notice any improvement. Installed Elkas and was a happy camper, made all the difference. On my 2019 RT I've done nothing, it rides great.
done both and loved them both as much!! Now come the tires!!!! As soon as I wear out my old ones!
Ditto here....almost. Ron's sway bar and front Federals. Those made a good ride even better. The rear will be a winter project or an impulse buy.I did not wait to wear out the Kendas, Federals on the front and General on the rear.
Imagine, if you will, how much more of an improvement the bar will make. If you ride aggressively, you will absolutely love the results. If you don't ride hard, then save your money.I just replaced my stock sway bar links with Baja Ron's for my 2021 RT. What a difference just replacing the links makes.
I'm just doing research and reading here before I make a purchase.
I'm curious how much does this all cost ? Sway bar+Elka+tires.
Do you have to change front and rear suspension to Elka ? TIA.
I did in this order.I'm just doing research and reading here before I make a purchase.
If the links from the bar to the A-arm are black plastic, then they are OEM. If metal - usually a color - that's a Bajaron. Especially if the links have that name, or another supplier's name on them.I am the 3rd owner of my 2015 rts. How can I tell if my sway bar has been upgraded to a Baja Ron's already ?
