BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
RSI RISERS
David, I found that brand of RISER back in 09 and used them on my 08 manual shift GS. When you have to grind them for the reservoir you can only mount them with the sloped end up facing forward, this allows for the least amount of grinding necessary. If you have a 4 1/2 angle grinder, I would get a very thin cutting blade and make your notch with that ...... Aluminum clogs most stones etc. very quickly but not a cutting blade ..... good luck ..... Mike :thumbup:I went back and saw you got them from DK. But would like to see a better picture around the clutch lever. Don't know how much different the RT vs the GS on room around that area.
David
