Pennyrick
Jumping to conclusions about the cause/causes of this incident is fruitless. There could be many possible reasons, and even more complicating factors or components. The extent of the damage makes reconstructing the exact cause impossible. The initial location of the fire on the right side points to the evap system componenets, but it also points to fuel lines and electrical wiring. As Bob pointed out, three things are needed for fire...fuel, air, and an ignition source. The fuel/air mixture must also be within the flammable range...neither too high nor too low. Given the lack of direct evidence, the cause of this one will, sadly, never likely be known. There is no sense in pointing fingers at the systems or components...or the Spyder's bad habits. Hopefully BRP will use this as a catalyst to take a closer look at some of these systems and reported problems, but expecting a quick, firm answer or unwisely modifying a Spyder as a knee-jerk response, is not adviseable. All any of us can do for now is have sympathy for Ann, be thankful that she was not injured, and wonder what happened.
Wise words that help extinguish a flammable topic.
