Three "Simple" Things (that BRP can do)
1. Revise limp mode for safety reasons. (Should be cheap if the programming can be modified.)
2. Dash mounted Powerlets.
3. Replace analog gauges with other functions, like voltage and oil pressure. Why repeat what is already available in the multifunction display? Additional gauges would be an actual upgrade, too...as originally intended. Should be cheap, as one gauge costs about the same as another.
I'll add another, maybe cheap, maybe not. Make the diagnostics OBD II compliant, so the diagnostics can be read with a standard meter.
I agree. And I would like to see the turn signal arrow lights on the gauge larger or brighter. It is difficult to see if the turn signals are on especially in bright sunlight.
3. Another vote for the dash-mounted 12 volt plug. :thumbup:
I had the "in Dash" mounted plug nstalled prior to my RS Pick-up in 2008 and Again this time around I am having it installed on my new RT. It SHOULD be standard. So convenient to plug in a GPS or a plethora or other Ram mounted electronic options
Three simple things will never happen.
For instance, A customer would hand me a piece that they bought somewhere Elise and ask me to correct the three worst things, So i would ; Then the fourth thing now becomes the worst, so it never ends until it becomes a ,
'' Homer'':shocked:
SIMPLE FIXES
HALLELUYEA.....PRO10is ......FOR PRESIDENT...........................WETHER HE WANTS IT OR NOT.......MIKE...:agree:
