Is your trailer a 2010? If so you may want to bring along vise grips, a drill or Lamont :roflblack:
What is he doing??
Drilling out the lock. That was the second one I've had that partially falls out leaving all of your stuff locked inside.
Thanks for all the good advice. Practiced backing up and now understand the issue. Watch word going forward is "plan ahead"
Ann - yep, it's a 2010. Hope I got one of the later locks.
When hooked up put a padlock on the trailer hitch instead of the pin they give you. That way you don't have to worry too much about it traveling without you. Just don't loose the key for it. Remember when in TRAILER MODE you have to get er up to over 5000 rpm infirst in order to go to 2nd. Think the same holds true for all the gears. Check the manual for that one. But the 5000 rpms to get out of 1st is a fact. Have a great time traveling, I did and the trailer is there but mostly unobtrusive. Watch you don't try taking the kitchen sink. The thing is HUGE!!!! lots of room for yer "stuff" if it gets squirrly repack in a diff way. :clap:Picking up my new RT 622 at Cowtown tomorrow. Any yips fir someone who has never pulled a trailer before?
Squirrly is a good indication of too light on the tongue. Shift a little weight forward. Remember, 30#-40# tongue weight....squirrly ...
Always double check your hitch latch, pin, safety cables, and wiring connector before you leave the driveway. Check the lights on the trailer to be sure they are all working properly...every time you hook it up. You will not even notice the trailer is there, for the most part, but if you have an SE, be sure to use trailer mode so you keep your rpm up. Remember that the trailer will cut in closer on the corners, so ride in a little deeper before you turn, and don't cut the curbs too close. Around gas pumps and such, I go very slowly and look back to make sure I am going to clear. When loading the trailer, adjust the cargo to provide adequate tongue weight. The tongue weight should be at least 10-15% of the loaded trailer weight for best handling. Finally, go somewhere secluded and practice backing up the trailer. It is tricky with the long Spyder wheelbase and the short trailer. If it gets crossed up, even a little bit, pull forward a bit and try again...as many times as it takes. Don't worry about all this advice, you'll be a pro in no time. The RT-622 is a sweetheart!
