CloverHillCrawler
Well-known member
OK , I have about 5-6 K on my Quatrac's and they are showing a lot of what I consider "abnormal" wear.
They are 165/60/ R15 and did have some scrub against the fender when doing "extreme" far left or far right input from the handlebars under load.
I made some adjustments to the fender to stop the scrub. But I did start to notice some unusual wear on the inside of my tires after my trip to the Cherohala, Dragon, and BRP when I got back.
Over the last couple of weeks the wear seems to be increasing some more and it is quite obvious that an alignment is needed.
I want to get it aligned but I also am planning to upgrade my shocks to a set of M2's before next spring.
My question would be align it now so the tires can hold up until the upgrade and replace the tires then and do another alignment.
Or not do the alignment and wait until after I do the upgrade and tire replacement. It doesn't feel like it needs an alignment while driving but I am worried about burning through these tires before I can do my shock upgrade.
Looking from the front.
"Passengers" side
"Drivers Side"
"Passengers" side
