TOTALLY CLUELESS AND IN THE DARK TO BOOT
I'm still thinking about this whole issue...
I'm not real keen on leaving a very expensive chunk of my wallet bolted to the center of the handlebars where some :cus: can make off iwth it...
A GPS hidden in the frunk (or top trunk) and linked to a Bluetooth headset might just fit the bill...
No video games; but it'll talk you through the process to getting where you want to be! :thumbup:
Bob, not a good idea. The visuals are very important. I would never want to rely on the Bluetooth alone for serious navigation. And you need to access the screen controls often. The solution is to simply not buy an expensive Zumo. Sure they're great but at $600+ it's not something I would be comfortable leaving on the bike and I don't want to have to remove it every time I run into a store.
Instead make a compromise and buy a slightly out of date Garmin closeout. These can be had for around $100 or less. Some are incredibly well featured. No they're not waterproof but when it starts to rain you can either pop the unit in a trunk or simply put a plastic bag over it. This works great and was even recently recommended by Consumer Reports as an effective solution.
If you really want a Zumo and have the $$$ for one, they're the best for motorcycles. But if you want a excellent GPS without spending a fortune and you're willing to compromise a bit there are plenty of low cost options. And you won't cry if someone walks off with it.
Thanks for this perspective! :thumbup: This is why I haven't pulled the trigger yet on this project; too much to learn still... :shocked:
i have always liked paper maps.. gives me a reason to pull over and stretch and scratch my head, wondering.. where am I now? and why doesn't this map fold up as easy as it came apart?
I,m with ya ! While others have I-Phone 4s and 5 I have a Trac Phone- Costs $6.77 a Month?:yikes:
If you wanted to go to the Audio and not the waterproof / see the map route, then the frunk with a 12v outlet and velcro'd would work fine. You could even go with an audio'd headphone / earbud, just need a cord to a water proof jack near the cluster and you can hook up some ear buds. Also you might be able to locate an earlier verizon of a garmin, put it in the frunk and have a BT adaptor. Either making it easy, and honestly less expensive.
If you wanna see the map however, pending your cellphone, there are LOTS of options.
There is a company out there that will 100% waterproof a phone for like 70 bucks, I bet they would do it for a GPS too, so you could probably get a sub 200 dollar waterproof if you did both.
Garmin 660 used in conjunction with the Sena headset....waterproof, great pairing with the Sena and my I-touch for tunes...can't beat it...nasty weather, just listen thru your headset.
I have the Garmin Zumo 550. Garmin says it can be submersed in a bucket of water for 30 minutes without a problem. Not that you'd have cause to do that but it shows its impeccable wet-weather credentials. The 550 is a discontinued model according to Garmin but they are still popular among British bikers and Garmin-refurbished examples fly off the shelves. It has a slot for a SD HC Memory Card which will hold maps, routes, mp3 tracks, etc. The 550 also has a BlueTooth connection for phone or headset. A comprehensive Operator Manual is available from Garmin on a PDF file. Lifetime Maps can be purchased. It's an excellent addition to my Spyder RT. :thumbup:
My 2 cents worth
I have had a Zumo 550 since they came out and have moved in thru 3 Bikes. It is waterproof but has a history of the touch screen going crazy, however this is a cheap fix if you don't send it back to Garmin. It can be self repaired with screen replacements from China via eBay (12-25 dollars) The entire unit can also be found on eBay relatively cheap. Mine has a docking system with built in lock, and is hard wired to the bike. SL site has a very cheap mounting system on Do-it-yourself which will cost you about $2 to fabricate. The supplied Garmin attachment will not fit the wide Spyder bars, so you must fabricate one or buy a $150 one from BRP. My friend has the newer Zumo that CanAm sells but he doesn't like the dim screen, my 550 is brighter and easy to see. The 550 has an upgrade able data base but I don't upgrade, so sometime I travel where there are no roads(According to my GPS) What ever you choose make sure you have a paper map back-up, my Zumo has routed me to some very strange places, which any GPS will do. :ani29: If you just want to find a restaurant or gas station go with the cheapie throw away in a plastic bag, your gonna want to do that anyway the first time it leads you astray
This is an interesting thread. I know an awful lot of us have been driving for a long time and hopefully, learned to use paper maps. Now that we have electronic devices we tend to rely on them too much, in my opinion, anyway.
In my way of thinking, if you're going to use a GPS the number one thing would be that it's easy for you to use and to see while going down the road. Maybe I'm old-fashioned, but before I leave to go somewhere I've never been I map it out on either a paper map or if I want to be modern I use Google maps. Then when I leave I hook up my GPS and use it for quick reference for how many miles are left, distance to turns, etc. I also will set waypoints for planned fuel stops, which works good for me. I use a Garmin 1550 mounted where my fuel gauge used to be and that works quite well. I never, whether on the bike or in my truck use the voice information.
Having worked with military GPS since it's inception, I trust it within the limitations of the units. GPS, when used with a proper map or chart, is accurate to two or 3 feet. To do this you must plot latitude and longitude. When we use a commercial unit we are at the mercy of the quality of their map. If it is not accurate then our position will not be accurate. I'll grant you that on a highway it's not that critical but in a city it certainly could be. You also have to pay attention to how your GPS is set. If you set for the fastest routes you get to ride lot interstates but if you set it for the shortest distance you will sometimes go on some crazy rides. That is why I preplan my trips.
A prime example was last week I met up with some folks coming from another town to eat at a restaurant here were I live. I did not realize that none of them knew how to get there or I would've offered to guide them. I know the ride captain took a lot of grief because his GPS led him down a couple of roads and they had to do U-turns to get where they needed to go. Once again, my recommendation is plan your trip before you go which helps limit the surprises.
Regardless of what unit you get you should make sure that it has free updates to the maps and any special features. Sometimes new roads open or old routes get closed down and you can go a long way out of your way before you find out that you lost.
Just my two cents worth...
Do you mind if I ask why? That is usually what I use the most. I have bluetooth and it makes it easier/safer (IMO) when in an urban area with traffic rather than looking at the gps.
Good luck with free map updates, if you have a garmin. Of course, I think with garmin you pay once and you are good for lifetime updates; but, what good is that if you buy a new gps every couple years.
GPS
Hi guys i have a Garmin Nuvi 1450 that i use in my car and would like to use on my RSS only problem is where to attach it even with the suction cup mount it will only stick to the guage panel so not a good spot any ideas im Cluless Thanks,
Mike
Thanks Wyliec i see the plastic ring on the bars does it have to be broken off or does the grip come off, also where should i look for the ram mount.
Mike
I always found the voice prompts distracting. By preplanning my trip I kind of have a picture in my head of what I should be seeing on the GPS. The few times I did get in the urban environment I preferred to follow the road signs with a quick check of the GPS. The model I have has good directions when it comes to exits by highlighting the proper lanes. Truth be told, I've sort of avoid urban areas when at all possible.
The Garman I have has free lifetime updates and I would not buy a GPS didn't have those. As far as upgrading, unless they launch more satellites or the unit dies there is no reason to replace it, unless you just want more bells and whistles. I actually have four units. I have an old tom-tom that still works although the screen is small. I also have a handheld that is great if you have a chart. I've used it on a boat with excellent results.
It really all boils down to what you're comfortable with, what you can afford and what your needs actually are. Personally, my favorite maps are set a motorcycle maps that fold nicely and are water resistant. They're very easy to read and show places that I would never find with the GPS.
So, enjoy the ride wherever it might take you.
TomTom
I use a $100.00 TomTom XL 350 TM and Ram mounts with Ram Medium-Wide Aqua Box. I drove with TomTom in the aqua box in a hard rain 15 times and kept the TomTom. Got them all on Amazon.com and they had the lowest price and free shipping.
Mike
To GPS or not
I use my smart phone. It has GPS navigation and point of reference so I always now where I'm at. If you have that type of phone, it should be a free app. Hope this help. Keep 3 on the road:thumbup:.
GPS
Mike,
I have all your answers about mounting a GPS on your Spyder and where to get the parts in the States. I did it successfuly on my GS SE5 2008. Contact me at
xe1ll@prodigy.net.mx. I'll be out of town for 6 nights so I will get back to you after the 24th or tonight if you are in a hurry. When you answer please give me your full name and street address for my files. You will have to have a plug in 12V outlet on your dash.
Arthur
Arthur S. Cohen
Ibsen 72
Mexico City, Mexico 11560
Need some help from the more technically savy people out there in Spyderland.....I am considering getting some type of GPS device for use on the Spyder......I think something basic will work for me...it does not have to have "blue tooth" what ever that is......of course weather-proof and handlebar mountable and model #'s so I can find it......Thanks all in advance........Your opinion matters.......Mike....:thumbup:
One thing worth mentioning with GPS devices is the ability to pre-plan routes and download them to the GPS.
All GPS devices will allow you to enter a destination, some will let you select different route types, shortest, fastest, economical route etc.
Whats nice is being able to pre-plan the route on the home computer, when I went to SITA i didn't just want to take the fastest route, I wanted to take a scenic route.
The Garmin comes with mapping software and you can even use google maps and import them into the mapping software. You can set way points add pictures and notes along the way etc.
If traveling to a new location I normally program the hotel and after some research places to see.
Mad Maps have been making scenic route maps for years, you can now buy and download them to the Zumo's I have the rallies and New England Mad Maps on my Zumo.
There are web sites out there that share GPS files so you can download some ones else ride.
They're also fun for getting lost, some days I like to take a road I've never been down before, just keep riding for a few hours then just hit home when I'm done.
POI's are great while on the road, being able to find the nearest whatever is great.
detours are great as well, stuck in road works or bad traffic jam, hit detour and your on a different route out of there.
There's a lot you can do with a GPS than just get you from A-B just need to play a little.
I have studied orienteering back in my university days of hill climbing and back packing and I'm very comfortable with a traditional map, but I wouldn't go anywhere now with out my GPS.
IMHO, worth investing in a really high quality full featured one.
just my 2 cents, not worth as much as it used to be.
harry
I'm pretty clueless too but I got the RAM X Grip that I saw Lamont use and am going to try to use my Tom Tom or Samsung Galaxy S III phone for GPS. Tom Tom is pretty inexpensive, phone uses Google Maps and both will talk to my Sena headset. Phone kills three birds as I can listen to music, receive phone calls, and listen to directions. Not sure if I am going to like it or not but ziploc bags are cheap if it decides to rain.
or sometimes in larger cities they change the road daily.. read about a person listening to their GPS telling them which way to turn and they did.. right smack into a concrete barrier that wasn't there that morning..
A little common visual sense come in handy,,,sometimes
btw.. no music has ever been with me on my rides.. I enjoy the peace of being.. only distractions/attractions I want, is what's in front of me..that's why I ride
however.. a radar dectector is very nice.. long ago and far away , a friend From Houston TX and I were ln the process of leaving Denver, CO. in the late 70's.. we were both up to twisting the limit.. I always rode in front.. as we were topping a hill.. my detector went into full tilt boogie mode and I slammed on my brakes.. went went from 85 to 55 by the time we topped the hill.. 5 state trooper cars lined up at an angle over the hill... we got glared at.. giGGLe.. if you want a GPS as well as Radar protection I suggest Escort, be it radar dectors or this http://www.escortradar.com/iq/
