trip a odometer reset
Mikesm
Does anyone else have a hard time resetting the A trip odometer the B one resets fine but cant get the A one to reset is their a trick to this, Thanks
:shocked: There shouldn't be...
I toggle to the trip odometer screen (I'm usually on "A").
I hit the down button to zero it, and the right button to move to "B"
Down, and right buttons bring me back to "A".
Are you getting a good-sized thumb, on the buttons?
NOTE: The UP button will pause them; I've never found a use for it...
Have no trouble getting to the screens for A and B, B resets easily but you can hold the button down to reset A and nothing ever happens, I have reset it before, but now it just will not reset
I have the same thing on my 2014 RT-s. I found a quick short press works best to reset "A" but some times take a couple of attempts. I also have better luck without having my gloves on. The reset on B works every time with or without gloves. I have no idea why but just assumed it was something I was doing wrong :). I am used to it and didn't think of it as a problem. I will be interested to see if someone knows why.
Thanks I'll try that when I get home from work, I have just been holding the button down until it resets works fine on B
Like they said--
Does anyone else have a hard time resetting the A trip odometer the B one resets fine but cant get the A one to reset is their a trick to this, Thanks[/QUOTE
A couple of times this has happened and if I focus on it it's worse (like a lot of things I guess).
A QUIK TAP IS WHERE IT"S AT!
Do what the display shows you to do. To reset the trip meter the display shows a single down chevron. That's a short press of the down button. Other functions display a double chevron. That's for 2 possible choices with the same button. Short press gives you 1 result and long press gives 2nd different result.
In most cases doing a long press with a single chevron does not matter, it will still work like trip B. In other cases I think the code was badly written and a long press does nothing, like trip A.
Thanks for all the responses a quick tap was all that was needed my bad but just thought it would reset like B holding the button down, That's what i get for thinking, Thanks again Mike
Glad to hear you got it figured out.
Sometimes, the :spyder2: likes to show us who is really in charge. :roflblack:
Thats why the A odometer quit working ???
Thanks Bob :bowdown:
A odometer stopped working at 17.1 miles. zeroed it back to Zero, and still not working. I must have hit the pause button at some time.:banghead: B still works fine. Funny how the little things bug you so much.
Something that I did not see mentioned above.
When the gauge indicator shows "pause" the system is on.
When the gauge indicator shows "resume" the system is paused.
Use the Right toggle button to go from A to B etc.
Use the Bottom toggle button to zero out either the A or B register.
The Top toggle button changes from pause to resume.
I'll admit that several times I've had problems resetting "A".
Lately I'm having more problems setting the cruise button. They sure need to make it with an insdent, or click, or something. Sometime it will just not catch and you don't know it until you've lost 10 MPH of speed. Some days it's fine, then not.
