major911
Well I seem to be in a jam, thought I could follow simple instructions. I have the grips off and controls both sides. I have free'd up as much slack as possible. Cut the bar on the left side funny thing the spot to cut was right in the middle of the slot in the old bar. made it difficult to cut and get riser onto. I have the riser on with the new bar segment trying to put the controls on (SE5 I might add) instructions say there's a pin that has to go into the hole in the bar. Unless I dropped something and lost it I don't see any pin or whatever is supposed to go into that slot. Don't have a shop manual so before you suggest that, forget it. I may have bitten off more than I can chew
