johnc1921
My wife and I have trouble seeing the turn signal indicators on the dash panel. Our Phoenix sun is too bright to show this indicator thru the dark smoke lenses on our helmets. I bought the Can-Am Spyder RT Side View Mirror Amber Turn Signal from SlingMods.
The install is pretty easy. A total of 4 holes (or three and a notch) need to be drilled to run the wires from outer trim hole thru three plastic pieces to the main wire hole. (I missed the first one close to the hole from outer edge.) Not cutting these holes makes it difficult to fit the mirror back on. In the garage and on their install video, the LEDs looked great. But outside in the bright Phoenix sun the lights were washed out.
I peeled off the LED strips from the upper, under side of the mirror trim and remounted it on the upper outside trim. Much better. For me this was the whole point. I cannot see the turn signal indicator on the dash panel due to bright sunlight and dark goggles. The LEDs are visible in all sun angles except directly behind me. Even so, I can see them well enough to know they are on.
