trikermutha
I copied and pasted from my manual. see below.
U0128 TCM BOSCH Lost communication with WPM/EPB (lost of CAN ID’s) Missing CAN ID 460h from WPM/EPB. Module internal error. Damaged circuit wires or damaged module pins. Check for TCM fault or WPM/EPB fault. With unit connected to BUDS with MPI2, Turn ignition switch OFF, wait for cluster to turn off. Disconnect MPI2 from DLC connector. Measure resistance between DLC-1 and DLC-2 (expected value = 50 to 70 ohms). Measure resistance between DLC-1 and TCMB-C1 (expected value < 2 ohms). Measure resistance between DLC-2 and TCMB-C2 (expected value < 2 ohms). Measure resistance between DLC-1 and WPM-6 (expected value < 2 ohms). Measure resistance between DLC-2 and WPM-8 (expected value < 2 ohms). Turn ignition switch ON Measure voltage between harness connector WPM-5 and ground (expected value = 11 to 13 volts
