I want to install a USB port charger on my Spyder RS. Does anyone know where I can plug it or if there is a accesorie cable?
And I don't want to plug it directly on the battery, I heard that it can drain out the battery. :sour:
Thanks
Thanks
Yes, go direct to battery. Even if you leave your phone plugged in would take WEEKS to drain the battery enough not to start it. Having said that - You know those two ugly needle indicators on your dash? Pull them out (they will show up on display now), and replace them. I put a 12V cig in one for universal use (GPS, CB, etc.) and the dual USB in the other. Lot of youtube videos about that.
I also drilled the hole in the left speaker cover (search youtube for Finless Bob's video). That is working well also. I run a USB cable to mine & wifes helmet on long trips, GPS and phone all going
You can also get the mount for the handlebars (putting the USB in the middle over the bolts), but IMHO that is not a pretty solution.
Another nice option is the mounting bar from one of the sponsors here that goes on the dash cover, under the wind shield. Has a kit to mount a USB there, along with RAM mounts to hold you devices.
Just my 2 cents!
Steve
Remember folks, he has an RS not an RT.
My 2012 RS has one of these: http://www.can-ambrpparts.com/oemca...342f98f6d81f5837c18d10a/12-v-power-outlet-kit
I simply plug an adapter into it that has two USB ports.
It's in the frunk, though, so not the most convenient place for something like navigation.
Does anyone know if the 2012 RS Sm5 has an sae connection near the front right shock, supposedly zip tied in that general area and possibly a picture of its location?
It wont drain the battery if there is nothing plugged into it.
