Use of a Floor Jack?
tconaagt
Are there any areas under the spyders that are structured sound enough to use a floor jack?(front & rear)
Sure
I use a floor jack all thee time. Under the lower control arm to raise the front wheel for cleaning or service. Under the rear swing arm just in front of the rear tire to raise the back tire.
I use my Harley jack stand. Slips right under the frame just behind the front wheels jacks right up balances great.:thumbup: I've lifted my Spyder in the air and left it for a couple weeks.:thumbup:
Use of a Floor Jack
My dealer used the same floor jack and one of the lugs dented the frame. If you have the same jack put some thing to cushion the jack plate. Just my two cents.
:agree: Preferably a rubber jack pad that slips over the cup. The Spyder will not lift perfectly balanced, and the rubber pad will keep it from slipping off the jack until you can get jack stands under it.
