IdahoMtnSpyder
Well-known member
IMPORTANT UPDATE: I discovered you cannot use a USB adapter connected to the power leads from the radio if you want to listen to FM radio. USB adapters emit RF noise to a varying degrees, but the few I tested all transmitted enough interference into the radio to really muck up FM reception.
Go down to post # 20 to see my solution for a USB adapter that works.
In the following posts I italicized and underlined text you should now ignore. I didn't want to delete it and there is no strikeout option available.
At a grand for the official BRP accessory GPS I figured there had to be a more wallet friendly option. After studying the wiring diagram for my 2013 RT I couldn't see any reason why any GPS, properly connected, would not work. My results proved me right.
There are two connections into the radio harness for the GPS, three wires for the audio and two wires for power. I thought at first that maybe the power leads had to be used so the radio would sense the presence of the GPS. I've been able to prove that is not the case. So, using the power leads is not required, but probably will be easiest. The Can Am GPS Adapter Harness is part # 710002182. A dealer can order it from Can Am parts for about $60. The gray painted GPS mount is part # 709400662 and is about $80. If you need or want to buy both pieces you're better off to buy the complete GPS Support Kit, part # 219400318, for about $155. A chrome support is available for more money. I bought this set on eBay for less.
Based on a comment in another thread it looks like the 2014 doesn't need the GPS adapter harness. The connections are already there. Someone correct me if I'm wrong.
If you are resourceful and comfortable working with the bike wiring you can get by without the Can Am harness. I can help you figure out where and what wires you need to tap into to do it, but the harness is a whole lot easier. You need two one more items to go between the GPS adapter harness, a USB power adapter (or other power cord if your GPS doesn't use a USB cable) and an audio extension cable. Here is the USB power adapter I used: [link deleted] Here is the audio extension cable I used: http://www.amazon.com/gp/product/B004OKKWDW/ref=oh_details_o01_s01_i01?ie=UTF8&psc=1.
The USB cable is connected to the power leads of the harness. The solder/shrink tube connectors in the kit worked great.
I put a piece of shrink tube over the audio connection, both to protect it and to help keep the connectors together. Here are pics of the cable assembly and connections. Here's the assembly.
DO NOT install the USB adapter as I show it here. It causes FM radio interference.
