Voodoo exhaust
nybbe79
Hi Sorry for my bad english, hope you understand;)
Got my voodoo exhaust system today (RSS 2014) and it looks really nice out, the original so sitting spring and washer on the outside exhaust system (see image), the image that was so sitting there between, which is right?
Hmmm
I believe our friend in Sweden is asking should the spring sit in the opening or as it is in his picture. My Swedish is rusty though, so I may be wrong.
Anyone?
Not sure..!!
It looks like you have it installed correctly. Never worked with voodoo but other systems are the same..:thumbup: send some pictures and sounds when your done...
The picture is with the original system, I found a picture of Voodoo systems om eBay , which spring sits in the middle, I did the same thing (see picture) but the springs bottomed so I hope it keeps tight, get to try tomorrow.;)
Either way will work as long the pipes are flexible when tight.
Spring on the outside would be my choice. It's the spring tension that keeps the pipe sections together. You don't want the spring pushing the sections apart.
