ButterSmooth
Thanks. Four times in exactly the same area cannot be coincidence. Happened NO WHERE ELSE (yet). I'm getting more convinced that it's something in the environment vs. on the trike. Some of the SIGINT stuff at Pearl and Camp Smith could be the issue. Think I'll wait a bit before investing $$$ in a BUDS for now.
Two more details that may be relevant. In an antenna field where there are multiple sources of radiation, there will be 'nodes' where the signals interact and create a high energy spot. You may have found one, and there may be others. Vehicles that use the chassis for the ground and wires for the signals are more susceptible to interference. The usual solution is running critical signals on twisted pairs of wires, signal and ground. If more spurious signal rejection is needed, the next step is shielding.
If the BUDS analysis identifies the offending sensor, you may be able to improve the electrical wiring and eliminate the problem. If it's multiple sensors it will be more difficult, but still may be as simple as wrapping the wire harness (not necessarily all of it) in foil and grounding the foil. Try the easy (and sensor relevant) parts first. It may not take much to make the problem go away.
