BajaRon
Well-known member
Hi,
just wanted to confirm, are the shift point recommendations only for the se5,or does it apply to the sm5 also? As the centrifugal clutch doesn't apply here, I wasn't sure.
Tia
Fas
Sent from my SPH-L900 using Tapatalk
Since all Spyders create the same HP & Torque at the same RPM, the same shift points are a good rule of thumb for any Spyder. However, a manual transmission will not suffer from low shift points like the SE models will. Still, if you lug the 998 you will eventually create problems regardless of model.
As alluded to in previous posts, 'Lugging' an engine has many parameters, only one of which is RPM. The harder the engine has to work, the more RPM you need to keep from lugging it. The easier the task, the less RPM is required to avoid 'Lugging'. So, other than the SE clutch lock-up RPM requirement, you can't realistically put a hard RPM number to this topic. And I think therein lies the.... Ahhh.... discussion shall we call it?
As examples (not absolutes), if you were going uphill into a headwind with a heavy load, it may require a minimum of 5,000 RPM. Turn around with the same load and you'd probably be fine at 3,500 RPM (even lower on an SM model because you don't have the clutch plate lock up issue).
On another note; an apology is due to the OP. And I, for one, am glad that I was wrong in my assessment of his post. I sincerely hope that something good comes from this thread for him.
