Wasted my $$ on Cardo Packtalk Bold - just wanted decent sounding Music, but it sounds like ****!
Rdrnr
I am so upset I wasted $400 on the Cardo Packtalk Bold. I really just wanted decent sounding music. Sounds like crap. Zero bass, sounds like none. Tried a bunch of things and nothing seems to play nice with Sirius Satellite radio as well as Apple Music. Total waste of money.
The speakers need to be pressed pretty snug against your ears for you to get any bass. I'm more about comfort than good sound, so I set mine back a bit into the helmet's speaker pockets and just listen to music at home.
Then don't buy a Sena!
The Cardo JBL speakers sound much better than the Sena Harmon Kardon speakers.
What are you using as a music source (e.g. is the headset paired to the bike, or directly to the phone)? My Cardo Headset sounds terrible paired to the bike, MUCH better when paired just to the phone. You will never get great sound from a motorcycle headset, but the Cardo with the 40mm JBL speakers is as good as I've found. I've tried multiple brands, Sena is way worse.
My Cardo Edge with the 40mm speakers sounds good. I even have the half helmet kit with some speaker pockets from Amazon added with the JBL 45mm separate speakers they sell that sounds good. Nothing I would call amazing, but good. As was previously suggested, try moving the speakers around in the helmet pockets. I bet that's where the problem is, it took some fiddling with mine.
Thanks for the replies. I have tried moving the speakers. Even put them on top of the helmet foam above the speaker pocket to get tight against ears (annoying) didn’t hear any difference!?
I'm connecting directly to the phone, via Sirius, which I can’t find any equalizer to work with; and Apple Music, which does have an equalizer, but it is just pre-made profiles or filters, with no real adjustment.
The Cardo Bold is arguably the best helmet sound system out there. Even the latest Sena is no match for overall performance.
Battery life, volume, clarity, wind cancelation, are all better with the Cardo.
You didn't mention whether or not you have the upgraded JBL larger speakers or not. Also, if you do, make sure you have the updated JBL profile loaded in the Cardo App to take full advantage of them.
Wow! I have not found that, thanks.
I have a SENA, can't complain as I don't know any difference. The OEM speakers, if turned up, sounded more treble or high notes. So I tried some upgraded speakers that were suggested by a friend. Better, but not great. I finally just went with in ear monitors. Much better, and as a bonus, it knocked out some of the wind noise, etc.
Why don't you try a pair of earphones. I use them hooked into my Sena and it sounds fantastic. My music is loaded on my phone. Phone and Sena are paired to my GPS, so I can control everything from the GPS
I use Plugfones with my Cardo. I wired the earphones through my helmet. They dangle with the helmet off but so what? It's a little awkward sticking them in my ears while putting on the helmet but completely workable. They cut down a bit of noise to protect my aging ears and provide good audio from my phone's Bluetooth connection. I have a pair in my wife's helmet and we can talk clearly to each other while riding. I can still hear the important outside noises as well.
Definitely worth a try. They're cheap. There are different earpiece types and sizes.
Mine look like this:
Got them from Amazon. You can go as low as $15 or so, and up to over $200. They sit pretty flush with outside of my ear, so they're not usually a big problem getting the helmet on.
I've tried a few different types of ear buds and haven't found a set yet that blocks out enough windnoise to allow me to hear. I've tried multiple helmets as well with no luck. Having small ear holes isn't a great thing neither, fat head with small earholes is not a good combo LOL.
I like the look of those djh3, brand?
Do you find they protrude too far into the helmet pressing into the ear?
I hadn't thought about them in awhile, but I used to fly a lot for work.
I tried several types of earbuds to listen to music while flying and to reduce the regular noise in flight, and eventually ended up with a pair from Etymotic.
The ones I bought came with several different sizes of the tips that fit in your ear, and a small tool to remove and install the tips.
Looking at their website, they even have a "bass boost" version.
@Jetfixer: Can you please explain how to get the JBL profile. I've not heard of that and am curious and wanting to keep up with the latest advances. I have the BOLD and the Packtalk. Both sound great, but I don't have another reference, but from the replies here sound like they are the better choice. One thing I did notice right off the bat, the EDGE bluetooth has MUCH better range than BOLD - at least for me.
Also, if you happen to have an iOS device and use Music app, check out this app. it boosts the volume much higher than the stock iOS device. https://louderlogic.com/
The activation process for these profiles involves using the Cardo Connect App, where users must unlock the Audio Profile section and scan the QR code provided in the 45mm Audio Set package or enter the code manually.
Have just updated from Pack talk bold to Pro, the increase to 45mm speakers does improve the sound quality bur they are all pricey.
Al in Kazoo
