Hello,
I'm a new member here as I just purchased a used 2011 spyder RTS with 2,300 miles total. I live in eastern Pa. & I have driven the bike locally about 200 miles in outside temp. of between 60-75 degrees. Each time I take the bike out the temp. gauge runs very close to the overheat mark and sometimes right up to the bottom mark but never in the red. Even when I idle it outside it run right up to the bottom mark of the overheat section. To me this doesn't seem to be right but I'm not sure. Is this normal for this engine or do I have a problem with my cooling system? I have checked the radiator overflow when it is cold and it is just above the low mark on the tank. I'm a little concerned what is going to happen when I ride it in the summer time next year? Any suggestions?
