BRP &/or most dealers won't easily divulge anything in the way of alignment settings that's all that useful to you, so I wouldn't hold your breath on getting anything 'official'.
Still, if your alignment bloke is switched on as well as being skilled & competent, they should be able to set your Spyder up so that the steering is centred & pointing straight ahead
according to the DPS (Power Steering) without using BUDS & then they can immobilise the handlebars/steering in that position & move on to do the alignment. :thumbup:
From there, that skilled & competent tech should be able to do the alignment taking into account the centreline (thrust) of the rear wheel as necessary, the (now centred) steering, and your normal load (rider, passenger, anything you usually carry
) cos all those things can vary the toe readngs, and Toe in/out is the only readily adjustable thing you can access for alignment.
These days,
most manufacturers generally specify the
Toe-In to = ZERO with the normal load aboard, but I & many others have found that our Spyders benefit from
some Toe-in. For whatever good it does for you &/or your alignment tech, I use 3mm of Toe-In (1.5mm each side) at the tread for 'normal riding' & touring etc; and up that to 5mm of Toe-In for track work & ranging it thru the twisties, but then I can (& do) change & check those settings myself (using my 'home groan' laser alignment kit
) & I also swap in/out other tires for testing purposes on a fairly regular basis.
If your local bloke is willing to give it a go, then it's likely the major hurdles your they'll run into (besides having balancing gear to suit the little spindle hole in Spyder wheels
) will be getting a jack in underneath your Spyder; making sure the steering is centred & the rear tire thrust isn't skewing the front alignment too much; and finally, not having those two rear tires that most cars have to hang the reference gear on! But like I said above, a switched on tech who's got some idea of what they're doing
& the time to sort it all out should be more than up to the task! And once you
DO get your Spyder aligned properly, I reckon you'll be more'n just pleased with how smooth it can steer!
hyea:
Good Luck! :cheers:
