What are the best tires to use for a Can Am Spyder?
djflplayer
What are the best tires to use for the Can Am Spyder RT Limited 2019 instead of Kendra Tires. I've seen a few different ones out there but would like to know anyone else experiencing better tires. Thanks
I had three kenda kanines installed, a good difference from kenda OEM.
FlyBoy2121
Auto Tires for Spyder
:chat: Check out the, "Vredenstein" or General Altima tires for the rear.
Also check out your local dealer and see if they will install it
Good Luck on Your Mission. ....:thumbup:
I have these tires on my :spyder2: and couldn't be happier.
Car tires! Beyond that there is no single clear cut answer. Do a search and read hundreds of posts here and you will realize it's your choice, and yours only. But you will pick up a lot of good info to help you decide which one you want to go with.
