What average miles before Brake pads need replacement?
Average mileage for brake pads can vary by quite a bit so I don't really know if there's actually an average. Like Bfromla mentions that many different riding styles exist that can shorten or extend brake pad wear. Get yourself a small mirror like a dentist's tooth mirror and a small flashlight and you can check your brake pads for their thickness. Also, keep a check on your discs for marks indicating your pads need replacing. You may hear the scraping sound if you let them go too long. By the way, pads are not difficult to replace. Bleeding your system is also not difficult. BajaRon sells all the parts and supplies you would need to change pads. And, there is a week's worth of reading on this site about the subject.
:agree: X's 10 ..... I have a 2014 RT and ride hard in the twistie's in very Hilly area's .... I did my rear Pads at 30.000 mi. and I was lucky I did ... I had maybe 1000 mi. and would have hit metal .... I bought Ron's EBC pads and now have 35,000 mi. on those and I can still see over 2mm left .....I will examine them closer in November .... I did the Front s Pads at 43,000 mi. and could have gone at least another 5000mi , but I changed them anyway ( again w/EBC ) ..... Ron's EBC pads definitely last longer. But this was on my RT, you may get more --- but you also may get less .... you MUST check your own ..... Mike :thumbup:
As you can see mileage figures on brake pads will be all over the board. I ride a lot of twisties and I use downshifting and engine braking a lot. My rear pads needed replaced at 27,000, but the fronts were still in decent shape. I went ahead and replaced all three sets at 27,000 with EBC. The front pads get more cooling air and run a lot cleaner than the rear pads. A lot of heat from engine, exhaust system, etc. passes over the rear pads plus look at the dirt build up on the rear wheel compared to the front. Rear pads live and work in a crappy environment.
At 14000 miles my front pads were done. Right outside pad wore down to metal and scored the rotor. All other pads - front and rear - had maybe 1000 miles left. I replaced the rotors and pads with EBCs. I ride hard and use all the straights I can before braking for the curves. As stated already, it all depends on your riding style and you need to do a visual check occasionally.
WOW, the mileage difference between your Pads and mine are HUGH ( see my post #4 above ) ..... Mike :thumbup:
Do the rear brake pads wear faster than the front? I took both my front pads out and looked at them. They were good at 21,000 miles. I have not taken the rear pads out.
Usually they do because more pressure is applied to the rear pads than the front pads. That's the way the spyder is set up to function. Safety reasons.
:agree: .... also don't forget you have FOUR Pads for the front and only TWO pads for the rear ..... Mike :thumbup:
when you look at your pads the minimum thickness is 1mm. That is really thin and I replace mine before they get that thin. Also the factory pads are thin to begin with. The rears will wear out quicker then the fronts maybe twice as fast.
The pads are super easy to replace, esp. the fronts. Don't forget to get some anti squeal paste to put on the backs of the pads. Cover the entire backs. Any auto parts store will have it. Otherwise follow the directions that Ron sends with the new pads,they are very good and very complete(another reason to buy from him). Let us know how it goes and if you have a question during the process let us know.
